just finished them up today, KYB AGXs and some poly shock boots. the stock upper strut mounts will be changed out for the J&M units which will be on the car this wednesday to make the upgrade complete!
i was wondering what you guys are running on the struts... like what setting for the street? my car has cut moog 5664s so there like 1.5" lower than stock (one full coil cut) and my spring rate should be in the 850-900lbin range.
ive read ppl run setting 1 on the front and 2 on the rears for the street with sportlines/prokits. my springs are a good bit stiffer so not sure what i should run.
