Rear spring change this easy?
Old Feb 3, 2010 | 09:21 AM
1988GTA500HP's Avatar
Car: 1988 GTA
Engine: 400 CI
I noticed when my son's car is up on jack stands all the pressure is released from the rear springs and you can almost pull them out. Can I just get a spring compressor, compress and remove the old ones, compress and install the new ones, and be done with it? Seems too easy so afraid I am missing something. Thanks for your help.
Old Feb 3, 2010 | 09:29 AM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Re: Rear spring change this easy?
You also need to unbolt the rear shocks, and maybe the panhard rod; no spring compressor is needed. But yes, it is an easy job.
https://www.thirdgen.org/springs
Dennis Mecham raced these with lowered springs, and when the car goes on a lift the short spring fell out. So they bolted a steel cable to the lower control arm and the rear subframe so the axle wouldn't drop as far.
Old Feb 3, 2010 | 09:42 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Unbolt the shocks and lower the rear a bit (not forgetting the rubber brake line) and you're set to go.
JamesC
Old Feb 3, 2010 | 10:16 AM
Car: 1988 GTA
Engine: 400 CI
Thanks guys. I should have known I would have to unbolt something. Seemed too easy. Something I forgot to mention, it's an 88 GTA with ws6 suspension. Well at least I think so cause the center caps say that and it has performance suspension tag on the dash and rear disk brakes. Do they still use the stock springs?
Old Feb 3, 2010 | 03:25 PM
BMR Sales's Avatar
Former Sponsor
It almost is too easy.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
sailtexas186548
Aug 26, 2015 03:32 PM
johanlindgren
Aug 16, 2015 12:16 AM
kyleb24
Aug 15, 2015 08:24 AM
