Power steering from power
Car: 89 Firebird
Has any one tried to use an electricly driven power steering pump?
I was thinking about maybe getting an electricly driven hydraulic pump out of some wrecked vehicle and using that to run power steering.
Car: 89 Firebird
Re: Power steering from power
Bump
So no one knows of any one who has tried it?
I will have to give it a try.
Car: 1989 Trans Am GTA
Engine: Stock LS1
Axle/Gears: 3.70 9 bolt
I've never heard of it being retrofitted into a car, but several OEMs use it. I know that the Mazda3 and 5 use elecric pumps, but are not simply a power/ground hookup type of set up. Might be a place to look though.
Car: 92RS
Engine: 305 TBI
Transmission: 700
I would think that most automotive Electric/hydraulic Pumps wouldn't put out enough volume. I only see a small advantage to be gained in rear wheel HP and MPG.
Now having said that a well engineered electrically driven PS system would be way cool, not to mention the bragging rites.
I would start by finding out the flow and pressure on a stock pump so I had some idea what I was looking for in a replacement. Remember that a stock pump spends most of it's time at zero pressure. it's not until the spool valve is biased from input via the steering wheel that pressure is created in the circuit. Flow however is constant. 1967 Novas used a "power assisted steering" system that was a variation on the common power steering system used today. you might find some design ideas looking at that system.
Good luck, It sounds like it will be an interesting project. I hope you will keep us up to date on your progress.
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
i've heard some '88 fieros had an electric power steering
pump,but i do not know any details
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
yes some cars use electric power steering. Believe some corvette's have electric magnetic assist power steering. Uses magnets on the steering shaft and no hydro driven pump. This can and has been done before many times on factory cars.
Squeaky8791
Feb 5, 2020 08:29 PM
Chuck84TA
Jul 15, 2016 09:05 PM
