85 IROC Suspension advice
Car: 1985 IROC
Engine: L69
Transmission: 5spd
The restoration of my 85 IROC L69 5spd t-top is down to suspension. The motor has a mild cam, Edelbrock carb, headers. If I ever go for more power it would be in the 350 hp range. It is a t-top car and I dont plan on taking it road racing on track. However I certainly plan to drive the car and want it to handle as a new IROC did or better without losing ride quality. I have stock IROC rims and spec goodyears and plan to replace all bushings with polyU. What would you guys suggest for a shock/strut/spring package? I assume there are some options available now that would be better than the stock equipment available in 85. I also want to avoid getting new springs to stiff that increase the tire fender gap. I would appreciate any advice or experience anyone has. Thanks!!
Re: 85 IROC Suspension advice
First forget about springs, they non-factor in your supension. 25 yr old car, so lets start upfront with steering (Spohn has a kit for one stop shopping), end links (ft & rear), front struts & rear shocks, SFC to tighten up the uni-body, rear lower control arms, panhard bar those bushing you planed on. Also you could add front strut support.
This is about it, in my opinion for a good daily driver. Just so you know I have and installed the above listed items on my car.
Car: 1985 IROC
Engine: L69
Transmission: 5spd
Thanks for the advice. Looked on Spohn and I see the front end rebuild kit but I dont see a complete kit as you mention. I also see the SFC and rear control arms. Many shock and strut combinations available from bilsteins, tokico blue and kyb either adjustable or non. I was thinking the Tokico blue for my application along witht he other Spohn parts you suggeted. What shock and struts did you use? Thanks!
mustangman65_79
Aug 11, 2015 03:17 PM
