Power Steering Removal?????????
So... Over the weekend i got a new belt, dropped the A/C compressor and Smog pump... Now i'm thinking that i might want to drop the P/S too... I was thinking that if i run the lines to a vented tank, that it should be ok without the pump.... Any comments or ideas???????
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Power Steering Removal?????????
If driving on the street, using a power box without hydraulic pressure will be hard to turn and will wear out the steering box. For a race application, it's common to loop a hose over the 2 ports but this still causes difficulty with the steering.
If you want to eliminate the power steering, the best option is to pick up an S10 manual steering box.
Fronzizzle
Mar 18, 2019 08:29 PM
colton_carlson
Mar 8, 2019 12:21 PM
backtothe80s
Sep 5, 2015 12:39 AM
