83 Rear shock tower repair.
Old Mar 11, 2010 | 12:03 PM
jpw83's Avatar
Car: 83 CAMARO
Axle/Gears: 3.43
My 83 RR shock pulled out from the body.
The metal there is torn up. I'm trying to find a good way to weld/reinforce the shock mount. Maybe a repair kit exists but I haven't found one.
Anyone have a fix for this? It's parked till it is fixed.
Old Mar 11, 2010 | 04:28 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 83 Rear shock tower repair.
no repair kit.
it should be pretty easy to make up a little patch plate out of a piece of 1/8, cut to fit the area with the propersized hole in it. That or washers welded in place work too.
Old Mar 11, 2010 | 07:01 PM
jpw83's Avatar
Car: 83 CAMARO
Axle/Gears: 3.43
Originally Posted by //<86TA>\\
no repair kit.
I've welded a large flat washer on top but I don't think it will be substancial. This area is double thickness unibody, not too strong. Another piece dished for welding underneath may be okay. I have new NAPA Sensitrack gas shocks so it will have to be strong. This area takes a beating. I may take it to the local muffler shop for a good mig-weld job. That would be Rainbow Muffler in Jacksonville FL. Otherwise it is a good, fun car.
Thanks for your reply.
Any other ideas would be appreciated.
J~
Old Mar 11, 2010 | 07:19 PM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
That area should not take a beating. The body rides on the sring while the shock just dampens the bounce.
When the shock is lose and the rubber is all gone it does rattle around there and beat the crap out of the hole making things worse.
A person that knows what they are doing should be able to get to the thick area underneath and V out the cracks and weld it and then weld the inside and make it all fine. A body shop would and should know what they are doing and maybe do a better job than a muffler shop who usually just weld thin, non-structural, metal.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
NORTz89
May 20, 2020 03:51 PM
deracer
Apr 11, 2016 12:04 AM
kevyb1973
Aug 24, 2015 04:11 PM
