wearing out plastic inner mudgards !
Old Sep 12, 2000 | 06:11 AM
ausrs's Avatar
well the title says it all over the last few weeks i have noticed that my inner mudgards on the front are wearing away only since i put the stb on ...the rhside has a huge hole in it ...ride heights are stock ....what should i do ???
btw i have installed new shocks front and rear !
thanks
steve
Old Sep 12, 2000 | 07:50 AM
Chuck Everly's Avatar
Steve,
What is causing the wear? Is it because the tire it hitting it, stones or what?
I can not see how adding a STB could cause the inner mudguards (I assume this is the plastic inner fender in the front) to wear. More information might help or a picture if you could post one.
88 IROC convertible
So slow it is timed with a sundial
Old Sep 12, 2000 | 08:02 AM
ausrs's Avatar
WHAT I AM REFERING TO IS THE TIRES WEARING AWAY THE INNER GARDS....oops and i am only running 235 60 15 which is the stock size for my car !
Old Sep 12, 2000 | 02:04 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Look for loose/missing 9/32" head hex screws. They hold the inner fenders to the framerails. There's also some fender bracing (between the front wheel and bumper) that should be bolted down.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
Old Sep 13, 2000 | 10:57 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
What condition are your front springs? Maybe you should change them too. It sounds as if the suspension is bottoming and tires rubbing the inner liner. It shouldn't, especially with stock tires.
MrPackstin
Oct 25, 2017 08:09 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
Night rider327
Sep 25, 2015 04:19 AM
reactor60
Sep 22, 2015 01:44 PM
Saxondale
Sep 15, 2015 06:42 PM
