Just replaced idler arm, but steering is still flimsy...
Old Sep 16, 2000 | 12:42 AM
dwl's Avatar
dwl
I havn't had it aligned yet..
I guess it's an improvement, but not by much. What else can cause the steering to be loose?
I did the idler arm because I was told it was bad when I went to get my alignment done.
The old one was loose.. much looser than the new one which is very stiff.
Old Sep 16, 2000 | 12:07 PM
JAY87GTA's Avatar
Have you checked your tie rod ends, ball joints, center link, and wheel bearings? Any of these will contibute to a "loose" steering wheel.
'87GTA w/ SLP Cold Air, MSD Coil, Airfoil, Gutted MAF, AFPR, TES Headers, HI-FLOW CAT, Flowmaster Catback, Energy Suspension Master Bushing Kit
Old Sep 17, 2000 | 11:43 AM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
dwl...My car had 125,000 on it when i bought it. It felt lose also first i then replaced the Idler arm. Like you it felt a little better but still not tight enough. Then I replaced everything bushings, balljoints, wheelbearings, tierods, I even bought a new AGR steering box. Much better i couldnt beleive it was the same car!
If your car has high mileage like mine did. Thats the first thing i would put money into. That and the brakes those two are the best mods Ive done so far.
Most places have a life time warranty so if you plan on keeping your car a long while you can pretty much replace them for free next time they were out. If you kept the receipt.
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Fronzizzle
Mar 18, 2019 08:29 PM
backtothe80s
Sep 5, 2015 12:39 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
