A little play in steering
Old Sep 30, 2000 | 06:41 AM
Jason_GTA's Avatar
Ok, heres the thing. My car has a little play in the steering YOu can turn it side to side about 20 degrees each way verfore it actually starts to turn the car. I failed inspection for it and now ineed to get it fixed. Do any of ou know what it might be or how to fix it.
Jason
1988 Pontiac GTA
Loaded
350 700R4
Old Sep 30, 2000 | 08:45 AM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
Jason,it sounds like to me that you may have a idler arm that is worn out.Get someone to turn the steering wheel back and forth while you check the idler arm for play.That would be the first place I look.If you replace it don't get the el chepo auto zone/discount part,get a Moog.It's about $69.00
Superman
Rev'n to Seven
Old Sep 30, 2000 | 12:48 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
I agree... I have the Moog idler arm on my car. Its much beefer part than the stock one. Also your gear box could be worn. You might want to invest in a new one. Like Superman said have someone turn the wheel back and forth. While you look at the whole setup from the gear to the tierod ends. If the tierods twist in your hands easy they should be replaced.
Could be something as simple as a worn ragjoint.
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
Old Sep 30, 2000 | 04:29 PM
POS Camaro's Avatar
Car: 1986 Camaro Z28
Axle/Gears: 3.73 Posi
Look for a crack in the frame just in front of the power steering box. That will give a lot of play. Been there, done that.
1985 Camaro Sport Coupe
LG4, 3.08 rear, A4
Bone Stock
1999 Blazer
4x2, 4.3L, 3.42 rears
Decidedly slow
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
Night rider327
Sep 25, 2015 04:19 AM
