Getting airborn
Old Oct 2, 2000 | 07:53 PM
Monkie's Avatar
Getting airborn
Ok I was at a red light and my friend was next to me and I figured he wanted to race cause we always do. Anyways Im getting ready reving and then the light turns green and I pop out the clutch and I didnt really burn rubber just felt like the rear was raising up. And so after we got to his house he told me that my rear end basically lifted off the ground! Whats going on? Oh and Ive got a V6.
Old Oct 2, 2000 | 09:00 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
It's called wheel hop. Your rear suspension unloaded and the rear of the car lifted up. It's a good way to break a ring gear or snap an axle.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car and knocking on the SuperPro ET class
383 stroker (carbed) with double hump cast iron heads and pump gas
LS6 Big Block buildup now in progress
Best results before the engine blew up
Best ET on a time slip: 11.857
Best corrected ET: 11.163
Best MPH on a time slip: 117.87
Best corrected MPH: 126.10
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
Old Oct 2, 2000 | 09:22 PM
Monkie's Avatar
So how do you fix this? Thanks.
Old Oct 3, 2000 | 11:03 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Lower Control Arm (LCA) relocation brackets. Also check the torque arm bushing is still in good shape. Basically your rear end is twisting under load. The LCA and torque arm combined are designed to prevent this. If your car is lowered, or the springs are weak with age it also will exagerate it happening. When the car is lowered the geometry of the LCA is changed for the worse. The rear mount is supposed to be lower than the front. Read more about it on Global West's or Steve Spohn's web pages. Good luck, Lon.
cattiveria665
Apr 15, 2014 07:26 AM
Gumby
Theoretical and Street Racing
Mar 17, 2011 10:42 PM
