OVERSIZED BALL JOINTS
Old Nov 9, 2000 | 09:07 PM
MY87ROC's Avatar
Car: 87 IROC
Engine: 5.0
I think I need new ball joints both tires seem a little lose and tire wear is really bad especially on the inside also stuts are original 83000 miles they will be replaced to. since i need new tires i feel this is really necessary to fix first. My question is about ball joints, i have seen oversized ball joints for use with worn spindles, so how can you determine if the spindles are worn enough to need the oversized balljoints.
thanx
TPIS airfoil,relocated MAT,AFPR,TB h2o bypass
otherwise stock 5.0TPI
700r4, 9 bolt 3.23 g92 axle
Old Nov 9, 2000 | 09:41 PM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
You shouldn't need oversized balljoints. Theres's no wear where the balljoint and spindle fit together. It's the internal part of the balljoint that wears out.
Just get factory replacments, preferably by Federal Mogul, and you'll be fine.
Ed1LE
Sep 30, 2018 09:14 AM
Thirdgen89GTA
Oct 19, 2015 09:27 AM
88CamZ
Oct 8, 2015 10:29 AM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
