Well I changed Struts Today!
Old Nov 11, 2000 | 06:55 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
i took on the task of changing my struts. Let me say it wasnt hard at all. I want to say thanks to everyone that posted to my question, you guys made it alot easier.
Man!,when I losened up my struts and tapped the top with a hammer the strut just collapsed and went together....boy I guess they were SHOT! cause when I took the binding off the new ones they sprung out and I had to push them together to get them to fit...anyway thanks alot....
wishmister@yahoo.com
1987 White IROC-Z
305 TPI LB9
700-R4 auto tranny
87,000 miles
Very Clean car
Performance Resource Chip
Flowmaster Muffler
Throttle Body Coolant bypass
TPIS air Foil
K&N's
Gutted air box
Accel 8.0 plug wires
Moroso Super Coil
Blue Streak Cap and Rotor
AC Delco Rapidfire plugs
Mobil 1 15/50 Synthetic motor oil
Mobil 1 synthetic Trans fluid.
[This message has been edited by Wishmaster's87IROC (edited November 11, 2000).]
Old Nov 11, 2000 | 09:08 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
Well, I don't know if you read my post that I put on the Z-28 board for you, but if you did, hopefully it helped... Not to tough of a task, huh? You didn't take your rotors off, did you...?
KAM
Old Nov 11, 2000 | 09:32 PM
I took it all off. I cleaned everything too. Rotors, replaced my calipers,different pads, "i didnt like the PF pads" changed the brake fluid again.
I just took ,my time with everything. But let me tell ya the struts were not hard at all.
I need to get it re-aligned tho....I like the specs the last person did "good tire wear" but what is a better spec. for alignment?
heres the specs. I got:
ah hell I cant read this paper to many numbers...LOL
help me out on this before I go get it alignd tomarrow....
Old Nov 12, 2000 | 12:40 AM
MY87ROC's Avatar
Car: 87 IROC
Engine: 5.0
hey wishmaster your experiance is very incouraging i am going to attempt new struts very soon,i just would like to know what kind (brand) did you get and are you happy with their performance thax
TPIS airfoil,relocated MAT,AFPR,TB h2o bypass
otherwise stock 5.0TPI
700r4, 9 bolt 3.23 g92 axle
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
redmaroz
Apr 25, 2017 07:14 AM
spaigo
Aug 21, 2015 07:46 PM
1992 Trans Am
Aug 9, 2015 04:32 PM
