Bearings in Steering Wheel
Old Apr 6, 2010 | 10:15 PM
acesag's Avatar
K guys so im not sure if this should go in this thread but. . .
I was installing a new ingnition switch last summer i started tightening the 4 torx bolts. As I was doing so the ring that goes around the shaft started to fall to pieces. The ball bearings were all over. I accidentally broke the black bearing ring that goes around the steering column does anyone know the part number of this or what to search when looking online??
Does this come as one part with the ball bearings or do i need to order both??
Thanks for your help guys
Old Apr 8, 2010 | 09:13 PM
383fbod's Avatar
Car: 88 IROC-Z
Engine: 383
Axle/Gears: 4th gen 3.42posi
Re: Bearings in Steering Wheel
I would say order a whole new steering shaft from a local parts store. It should be included there
Old May 25, 2010 | 08:48 PM
POP6482's Avatar
Car: 1989 Iroc-Z Convertible
Engine: 6.0 LQ4 LSX
Axle/Gears: Moser 12 bolt w/4.11s
I'm having the same problem with needing a new bearing. How did you make out? Can't seem to find them anywhere.
Old Jun 30, 2010 | 10:29 PM
gurkgurkgurk's Avatar
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
i just ran into this problem today. im looking all over for that piece. seems like a common point of failure
Old Jun 13, 2012 | 03:31 PM
rlewi771's Avatar
Car: 86 IROC
Engine: 350 ZZ4
Transmission: TKO-600
i have the same problem, anyone know anything? other than the guy that says replace the whole steering column
Old Jun 13, 2012 | 05:05 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
I lost one of the needle bearings ages ago when tightening down the 4 torx bolts. looked for ages for it, couldn't find it.
Said screw it and re-assembled. 10yrs and 18,000 miles later its still fine.
Course, I only lost 1 of the needle bearings, not alot of them.
Old Jun 13, 2012 | 06:18 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
If there are numbers on these bearings you should be able to get a replacement from Applied Tech. The number should be in the phone book.
backtothe80s
Sep 5, 2015 12:39 AM
wild1
Aug 27, 2015 09:01 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
