replacing power steering gearbox in '84 TA , 2 different suspension options???
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
I'm replacing the PS-gear box, it seems that is is on its way out and could actually sieze up
,good news is it's only going to cost me $189.00 from autozone ($500 at the dealer
) I didn't plan on replacing that unit any time soon,at least it has a lifetime warranty. I was offered the choice of "sport suspension" or "non sport suspension" I'm pretty sure that the '84 TA didn't have two different suspension options. If it did what would be the difference? and why would it matter for the PS gear case? my only guess is that the "sport equiped" part has a higher turning ratio,could it be 2.25:1 ? do I have to use the part for an '84? what year GTA has the riverfire, or whatever it's called,steering box? I can't see how it would make a difference either way,common sense tells me to get the PS box for the "sport" susp. equip.
) I didn't plan on replacing that unit any time soon,at least it has a lifetime warranty. I was offered the choice of "sport suspension" or "non sport suspension" I'm pretty sure that the '84 TA didn't have two different suspension options. If it did what would be the difference? and why would it matter for the PS gear case? my only guess is that the "sport equiped" part has a higher turning ratio,could it be 2.25:1 ? do I have to use the part for an '84? what year GTA has the riverfire, or whatever it's called,steering box? I can't see how it would make a difference either way,common sense tells me to get the PS box for the "sport" susp. equip. THe sport box is 2.5 turns, the regular one i s slower , not sure of the ratio, but probably similar to a schoolbus
The 1LE boxes are the 2.25 turn, maybe some others. There always seems to be a little controversy on this board when this topic pops up...
1984 L69, IROC look, tangerine orange
305 from 87 IROC, tossed peanut cam,
replaced with LT1 cam.
Uses gas as fast as i can pump it!
.The 1LE boxes are the 2.25 turn, maybe some others. There always seems to be a little controversy on this board when this topic pops up...
Engine: 2.2
controversy is good!
I don't see any reason why I couldn't throw a 2.25:1 1LE case in, 2.50:1 is what I have stock.
I don't see any reason why I couldn't throw a 2.25:1 1LE case in, 2.50:1 is what I have stock. Moderator
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The quick ratio steering boxes were not just on 1LE cars. My IROC had one. My 454SS truck has one. Look for a large Z cast in the steering box case.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car and knocking on the SuperPro ET class
383 stroker (carbed) with double hump cast iron heads and pump gas
454 Big Block buildup now in progress for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857
Best corrected ET: 11.163
Best MPH on a time slip: 117.87
Best corrected MPH: 126.10
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car
91 454SS daily driver
95 Homebuilt Harley
Best 60 foot: 1.662
87 IROC bracket car
95 Homebuilt Harley
colton_carlson
Mar 8, 2019 12:21 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
