GM part # info for 1LE brakes
Old Nov 22, 2000 | 09:39 PM
TopForm's Avatar
With all the interest lately in converting to the 1LE front brake setup on our cars, I thought I would post the necessary GM part numbers to make life a little easier! Hope this helps some of you guys out!
Spindle RH 18016738
Spindle LH 18016737
Caliper mounting bracket (2 req) 18016034
Caliper RH 10132828
Caliper LH 10132827
Caliper anchor plate RH 10132830
Caliper anchor plate LH 10132829
Rotors (2 req) 18016035
Inner bearings (2 req) 457196
Outer bearings (2 req) 457049
Grease seals (2 req) 3965092
Brake pads 12518935
Misc. Hardware (4 each of the following)
11508133
14084051
10268875
I believe everything is still available through your local dealership, but on the expensive side!
Brian
1987 Firebird Formula
"It's just like a chick...takes all my money!"
Old Nov 22, 2000 | 09:52 PM
Jason M 91Z's Avatar
Thanks Brian, good hunting!
-Jason M. 1991 Camaro Z28
"Its Blue."
Old Nov 23, 2000 | 05:32 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
Old Nov 24, 2000 | 08:37 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
You can get the rotors and calipers from AutoZone and maybe other parts stores, although you'll have to pay the core charge on the calipers the first time you get them. If the calipers have a lifetime warranty, you wouldn't have to pay anything more after that.
Oh, the brake hose part numbers are 18032328 and 18032329, and they are $12.29 each from Dal. I also ordered 2 "fittings" with part number that were $1.69 each. Problem is, I don't remember that these fittings are, but I'm guessing something to do with the brake hoses like either the banjo bolts or the copper washers...
Greg Westphal
'87 IROC 305TPI/A4
Old Nov 24, 2000 | 09:22 AM
MikeH's Avatar
Car: 90 IROC
Engine: 406
I was told you can reuse the stock hoses. You just need to replace the bolt and washer that connects the stock hose to the PBR caliper.
I just bought new hoses last year. I would like to reuse them if i could.
Old Nov 24, 2000 | 06:29 PM
Engine: 385 HSR
You can re-use the stock brake hoses, but you won't want to unless you don't want to turn your steering wheel through more than 1/2 of it's travel. I actually had the stock hoses installed because I thought they would fit, but I had to be very careful how I was driving to make sure I didn't stretch the hose, which could make it fail.
To see how much I could turn the steering wheel (not taking into account suspension travel, which would limit it even further), I jacked up the front end, took off the wheels, turned on the ignition, put the tranny in neutral (so the steering column wouldn't lock), and turned the wheels side to side. I think I could turn the wheels 2/3 towards each side before the hose was getting stretched. Also, the junction on the brake hose where it clips to the strut is at a different location too and didn't line up at all since the brake hose bolts to the caliper in a different location. The 1LE hoses are definitely longer, but I felt much better when I got them on there and didn't have to worry about how far I could turn the steering wheel.
Greg Westphal
'87 IROC 305TPI/A4
Old Nov 25, 2000 | 06:48 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Oh...okay.. IM adding new hoses to the list.
Thanks Greg... you have been a lot of help!
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
gta90
Sep 15, 2015 04:00 PM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
