bushings and sway bars......
Old Dec 11, 2000 | 05:17 AM
quartermileguy's Avatar
I have an 87 IROC and i'm going to rebush both front and rear with POLYGRAPHITE bushings, Performance Suspension Tech (www.p-s-t.com) sells the front kit for $159 and the rear for $50, anyone know of a better deal?? Also i was going to replace the sway bars....should i go as big as i can or stay stock size?? p.s.t sells a front bar as big as 1.25" and a rear 1" for $119 each.
any feed back will help....also i didn't see any bushings for the rearend's bar that is sideways, sorry don't know the name of it but you know what i'm talking about!
Old Dec 12, 2000 | 09:12 AM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
You can get the 1LE front and rear sway bars from Van Dever's.The front is a 36mm (part#14094344) for $118.88 and the rear is a 24mm (part#10035033) for 92.72.The end link kits for the sway bars are part#10221779 and cost 14.43 a set.The phone number over there is 1-800-362-9494 and speak to a guy named Dale,he can held get ya hooked up.
Superman
Rev'n to Seven
Old Dec 12, 2000 | 01:59 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
Jegs has the poly bushings for the panhard bar #355-37106G 17.69 a set.
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
