Need a posi rear for my V6 bird
Old Jan 18, 2001 | 12:52 PM
FBODY-ADDICT's Avatar
I'm swapping in a 3.4 in for my 2.8 so I'll have a little bit more power, I want a posi rear to get the most out of the few new ponies in my car. Dont know anything about rear ends. What would work for my V6? Will a V8 rear off a Trans Am/ Z28 work well? Thanks for the ear guys.
Old Jan 18, 2001 | 01:37 PM
Bort62's Avatar
Yeah, a V8 rear would work Just fine.
They are the Same thing, Go Find a Posi rear out of a z28 or TRansam, and Bolt her in
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Livin' the Stereotype
Old Jan 18, 2001 | 02:36 PM
ERIC'86IROC's Avatar
I think the best route for you is to buy a Powertrax street locker which can be bolted into a non-posi rear end such as yours. I don't have one but I have heard only good things about them. The average person can install it in few hours w/o any special tools. You will then have a rear better than a Z28 for $315. A Z28 rear isn't any stronger(no differences) and since you have a V6 your rear end ratio is probably the desireable 3.42:1. This would probably be easier than swapping rears once you have found one out of a Z28.
350 Vortec, forged flat-tops, CompCams XE268, Edlebrock RPM, Holley 3310, TH350 w/Holeshot 2400, 3.23 posi, Heddman shorties, HEI
Old Jan 19, 2001 | 06:08 AM
Thanks alot guys, you definitely got me on the right track.
Old Jan 19, 2001 | 09:45 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Another possibility is to buy the take-off posi unti from SLP and swap it into your existing rear end. If your car has a 10-bolt and is from 90 up for sure and maybe 89 up, it will bolt right in and only costs $99.
www.slponline.com
ICON Motorsports
Old Jan 20, 2001 | 04:27 AM
Mike Harvey's Avatar
You really don't want a POSI unit. A locker unit is a much better buy plus you don't fishtail w/ a locker as you would w/ a POSI unit.
Also you would not want a rear end out of a Z28 or T/A. Their gearing is way different. We have lower gearing in our V6's than the V8's do. We have 3.42 gears while the V8's have like a 2.72 or something like that. While your at it install an aluminum drive shaft. It will help performance wise as well.
- Mike Harvey -
1986 Firebird S/E
Old Jan 22, 2001 | 10:41 AM
Red91Bird's Avatar
I dunno, i kinda like the fishtailing with a long wheelbase. I checked out the Powertrax street locker on their website and it seems they have 2 types for the 90's. One they make the other they don't. So which do i have in a 91 firebird?. I counted the rotation of the wheels to the drive shaft and do have 342's in it. I like the idea of no special tools, but which rear end do i have?
91 Firebird
3.1 w/
K&N filter, 160 stat, No TB heat, Direct Cold air, DynoMax CatBack, B&M MegaShifter, Performance Shift Kit,
Bosch platinum plugs,
7mm "stock" wires, Jensen CD330X Head unit, Jensen 120watt rear speakers
Stock front speakers,
0-30mph 4.25 Best 4.09
0-60mph 9.16 Best 9.09
colton_carlson
Mar 8, 2019 12:21 PM
87v6Bird
Jul 1, 2018 04:12 PM
90formulaVortec
Exterior Parts Wanted
Sep 7, 2015 07:17 PM
90formulaVortec
Sep 7, 2015 06:54 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
