Disk brake rear
Old Jan 27, 2001 | 07:33 PM
nc-iroc's Avatar
Car: 1989 Iroc-z
Engine: 1998 L31 350
Transmission: 700 R4
Disk brake rear
Can I put a rear end out of an 89 RS in my 89 Iroc. I know that it will fit, but can I put my 9 bolt disc brakes on the 10 bolt? Will changing the rear affect my wheel offset? Thanks.
1989 IROC-Z Original 350 was swapped for a 305! Why, I'll never know.
Old Jan 27, 2001 | 09:23 PM
ede's Avatar
ede
the 9 and 10 bolt brakes have differant bolt patterns. you might be able to transfer the hole pattern and drill and tap where you need to, but i don't know for sure.
ICON Motorsports
1st & 3rd
Old Jan 29, 2001 | 01:03 PM
nc-iroc's Avatar
Car: 1989 Iroc-z
Anybody else got any ideas?
Old Jan 29, 2001 | 06:40 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Nope wont work the 89 RS is a drum brake and the backing plates that the calipers bolt to are not removable from the 10 bolt, sorry.
Old Jan 29, 2001 | 07:17 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I don't know if the drums are the same from 87 to 89,, but my drum backing plates unbolted. I had to pull the axles to get them all the way off. I took the disc brakes off a 9 bolt rear and welded the backing plates onto my 10 bolt rear. Everything seems to work alright and lined up just fine.
Unfortunatly,, it's not just a simple unbolt bolt change.
<style>
< !--a{text-decoration:none}//--></style>
<BODY bgcolor="#00ff00" text="#00ff00" link="#00ff00" alink="#00ff00" vlink="#00ff00">
My Firebird
Part Diagrams
[This message has been edited by deadbird (edited February 05, 2001).]
Old Jan 30, 2001 | 06:56 AM
nc-iroc's Avatar
Car: 1989 Iroc-z
Thanks. Oh well, looks like I might just part that car out.
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
novaderrik
Aug 10, 2015 12:44 PM
