show me your chassis and cages? 7.50s cert 6.50s
Old May 14, 2010 | 05:08 PM
mattsv8_03's Avatar
Car: 89 Camaro rs.
Engine: 357 t88 turbo motor
Transmission: Powerglide
Axle/Gears: 3.55
hey guys im building my x275 drag radial camaro over the next few months into next yr. i want to see build pics of any cages 7.50 or 6.50 for fab ideas.
it will have a 400" little m with afr 227 heads. .650 lift solid roller custom grind, and blow through carb 850 on e85 same as the s10. looking to run high 7s. will have stock style suspension too. i have spohn tq arm with loops, offset lower control arms with rod ends, panhard bar with rod ends, and moser housing with tq arm mount.
im also installing a brace top bottom and back. will either have a glide or a th400. proably a glide cause im worried about too much wheel speed on the 28" tire. thanks guys.!!
Old May 14, 2010 | 06:41 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Re: show me your chassis and cages? 7.50s cert 6.50s
If you're building a 6.50-7.50 cert cage, buy the SFI book. There may only be a few TGO members who have and need a 7.50 or quicker certification. You would have better luck asking on Yellowbullet.
Anything quicker than 8.50 needs a spec cage. It all depends on what spec you're building it to . There are at least five different 25.x cage specs depending on vehicle weight or tubing type.
"Fab ideas" won't get you a proper cage. Specific questions to basic layout or positioning will help a build.
Old May 14, 2010 | 07:19 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
You can always visit the bullet for some advice
http://www.yellowbullet.com/forum/index.php
Old May 16, 2010 | 09:44 AM
daverr's Avatar
heres my 89 gta with 25.3/25.2 cage
Old May 21, 2010 | 12:40 PM
Shagwell's Avatar
Car: projects.......
^^^nice!
Check Stiletto's thread on here as well, he had a 25.5 done very nicely.
Definitely get the cert book from SFI as Stephen noted. If you want 25.2/25.3 for a cert faster than 7.50, you will need to use moly and it will all have to be TIG'd.
Mark_ZZ3
May 24, 2018 01:02 PM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
Nervous2
Oct 8, 2015 10:53 PM
FueledSoul
Sep 30, 2015 09:18 PM
SG91camaro
Sep 5, 2015 10:27 PM
