cannot find the top of the rear shock on the camaro
Old May 16, 2010 | 12:19 AM
Jovani's Avatar
i was gonna replace the rear struts on my 1991 camaro RS but "I CANT FIND THE TOP OF THE SHOCK!" how do you find it to take it off?
Old May 16, 2010 | 01:09 AM
camguy91's Avatar
Car: 1991 rs
Engine: 305 tbi
Axle/Gears: 2:73
Re: cannot find the top of the rear shock on the camaro
its simple really you have to pull the carpet back (towards the rear of the car)from where your backseats are and then there will be two foam pieces on either side pull those of and there ya go the top shock mounts
Old May 16, 2010 | 07:35 AM
Tash3r's Avatar
Car: 86' Sport Coupe
Engine: LG4 305
lol I had the same problem when I was doing mine. Yeah like camguy said, just pull the backseat forward then start pulling the carpet up from the lower corner's and you'll see the little foam inserts. Make sure when your installing them to have someone in there to make sure that the shock aligned in the middle before you start tightening it down.
Old May 16, 2010 | 08:53 AM
Twin_Turbo's Avatar
Old Apr 23, 2018 | 12:59 PM
willkietz's Avatar
I know this is an old post but if you have a convertible, you have to pull the seat belt tower off. So pop the lid and and the top and you'll have access to it. I imagine it is a similar process for other third gens. It's two t45 bolts and a 14mm. The other bolt where the seat connects to can just stay. Also unbolt the top mount first then the bottom and you should be squared away. Here's a link to a video https://youtu.be/JBQhxqiWRuU
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
1992 Trans Am
Aug 9, 2015 04:32 PM
