KYB Struts on an 89'
Old Feb 6, 2001 | 02:35 PM
Steve89GTA's Avatar
Well, changed those damn struts. MAN, even the Husky 500ftbs impact wrench couldn't lossen those damn bolts. Had to go forward/backward for 20min before it came loose. Anyway, the KYB's didn't come with a new (plastic?) dust cover so I used the old one (cleaned and greased her up). Is this ok? I also noticed the bolt doesn't have the flange on it...it came with a lock washer and a lock-nut only...I used these but it looks like the pressure is mainly on the ball bearing and not on the mount anymore (the way it was stock).
Thanks for you input!
89 GTA G92
305 TPI
WC 5spd w/3.45 rear
Accel Cap & 8mm Taylor's
Crane Ignition
Custom 4" Cold Air Induction
Jet Airfoil
K&N Airfilter
160 deg stat/fan switch
Hypertech Thermomaster Chip
Steel Rad
Cat back 3" Exhaust
HiGh FlOw Dynomax Cat
Old Feb 6, 2001 | 05:43 PM
Metalifann's Avatar
When I did mine, I used an impact gun. Just give the gun a couple of burps when the car is on level ground. I haven't had any problems yet.
Old Feb 7, 2001 | 08:59 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
No replacement struts come with the dust boot.
Ed1LE
Sep 30, 2018 09:14 AM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
tcflint
Sep 27, 2015 05:58 PM
