lowering a '92 RS
lowering a '92 RS
Im sure this has been asked before but how much do I need to cut off of my stock RS springs to lower it an inch?
-'92 RS with self-installed '95 LT1
-Heddman Headers
-TPIS throttle body airfoil
Kills
-'97 Mustang Cobra
-'98 V6 Camaro
-'89 5.0 ****stang
-'97 Sebring
-'96 ****stang Cobra
Losses
-'99 Mustang GT
-'96 Mustang Cobra
-'95 Z28 (good race)
-Heddman Headers
Kills
-'97 Mustang Cobra
-'98 V6 Camaro
-'89 5.0 ****stang
-'97 Sebring
Losses
-'99 Mustang GT
-'96 Mustang Cobra
Axle/Gears: 3.45, 3.27, 3.27
I don't recommend cutting springs to lower your car, especially RS springs. But if you are on a tight budget, pick up some Pontiac WS6 or Iroc/Z28 springs first. These are stiffer and will hold up better if you chose to cut them to lower the car. Don't cut more than 1/4 coil at a time and keep the spring cool in the process. Good luck, Lon.
Actually, if you are gonna cut springs, you want to have a spring with a lower rate such as the stock springs on sport coupes. Spring rates increase when they are cut. If you already have a stiff spring, you will have a very stiff (read: unbearable ride quality) spring after cutting. Important: DO NOT CUT SPRINGS WITH A TORCH! When heated, the metal will lose its tempering, causing it to weaken.
'68 Camaro - Vortec 350
'85 Camaro Z28 - 305 TPI - FOR SALE
'91 Camaro RS - 305 TBI
MrPackstin
Oct 25, 2017 08:09 PM
