Lowering
Old Feb 11, 2001 | 08:36 PM
84Berlinetta305's Avatar
Lowering
What is the easiest way to lower my 84 Camaro? Springs, spindles, shocks. I don't really know that much about suspension, but i do know that my car is up high enough to be confused with a jeep! Any help will be greatly appreciated.
Old Feb 11, 2001 | 09:07 PM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
Get a set of Eibach pro kit springs and it'll drop ya down about a inch.
Old Feb 12, 2001 | 07:14 AM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
If you can afford it, get some spindles for the front. Nothing compares to spindles. Nothing. Spindled keep your factory suspension geometry, so if you want to go more than an inch down, you'll need them. You can get away without them, but the ride, and handling will be greatly improved with spindles over just lowering with springs.
But what ever you do, do it!!! Lowering is the best mod you can do.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
http://www.spinfrenzy.com/stingerssx...easures.html#4
Old Feb 12, 2001 | 02:08 PM
How much does a set of spindles cost? I am not looking to spend too much, but some would be nice,
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
MrPackstin
Oct 25, 2017 08:09 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
92projectcamaro
Sep 29, 2015 07:07 PM
