Whats better.........
Old Feb 13, 2001 | 04:39 PM
matty350TPI's Avatar
Ok I have a decision to make. I can either keep my 10 bolt posi-drum setup or I can go to a 9 bolt disc set up with no posi. Which is better? If I go to the 9 bolt will I get only one drive wheel or will both leave nice big black marks? I don't know the difference. Anyone care to enlighten me? THanks
1988 IROC-Z T-Top
350 Crate engine
370ft. lb Torque STOCK
5speed Centerforce clutch
Old Feb 13, 2001 | 04:47 PM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
Man stay with the 10 bolt.If you go with the 9 bolt you will only be leaveing one rubber mark, hence the name one wheel peal for a open rear end. The 9 bolt parts are also alot higher than the 10 bolts.
