Steering tilt joint thingy
Old Feb 17, 2001 | 02:11 PM
Camaro's Avatar
Hey, I got a 86 Camaro with tilt steering and the tilt thing is screwed up. The steering wheel moves all around and I think it's the joint that's in there. I attempted to fix it myself and I've gotten down to where there are no more apparent bolts or screws to take out. And now I don't know what to do. The manual doesn't say anything about this. Does anyone know how to get down to that joint and take it apart or should I just forget it and get someone to fix it for me?
grey 1986 305 LG4 Camaro w/ 700R4
Old Feb 17, 2001 | 05:18 PM
Bort62's Avatar
I have the same thing, And I asked on here and they told me, But I havent got around to it. Look in the archives.
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old Feb 18, 2001 | 12:46 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
If the bearings are good, there are 4 reverse torx screws in the column. These are what always come loose.
You will probably only be able to get three of them tight.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
Old Feb 18, 2001 | 04:46 PM
Cosmik Debris's Avatar
My steering column did this. It could be the torx bolts the other poster mentioned or it could be the bearings in the steering column have collapsed. The bearing carrier is made of plastic and they fail. Pulling the column apart is tedious and most manuals don't show the procedure to well. I did mine, it took three days! It is not difficult per se but it is not incredible obvious (at least to me) how everything comes apart. If you work at it slowly going in through the steering wheel you can do it. I think taking the column out of the car makes it easier to work on.
Cosmik Debris
Ed1LE
Sep 30, 2018 09:14 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
Night rider327
Sep 25, 2015 04:19 AM
