cant get the strut nut off!
Old May 23, 2010 | 09:32 PM
Red87SC's Avatar
Car: 87 Trans am
Transmission: built 700R4
Axle/Gears: BW 9 bolt posi w/ disc
help guys!
I tried for like an hour to break the strut nut loose on my 87 TA and it just wont budge.
I jacked the car up and put it on jack stands, then put the jack under the a-arm and compressed the strut little by little trying to get the nut to break loose everytime i stopped. Normally the struts have an allen key hole in the top so you can just put the allen key in it, and bust the nut loose while holding the allen.
i tried to holt the strut rod with vice grips and tuen the nut with a closed end wrench but to no avail.
Any ideas? I will be replacing the struts so if it requires destroying them, ill do it.
Old May 23, 2010 | 09:51 PM
TheMonster's Avatar
Car: 1983 Z28
Engine: Forged 355
Re: cant get the strut nut off!
Use a breaker bar,
http://carphotos.cardomain.com/ride_...0088_large.jpg
^^^ There is a cheap one rofl..
Old May 23, 2010 | 10:10 PM
Red87SC's Avatar
Car: 87 Trans am
i have a breaker bar. You cant use a socket on it because the strut shaft will just spin around... which is why you have to hold it with something and use a closed end wrench to remove the nut.
Old May 23, 2010 | 10:22 PM
chevysquid's Avatar
Car: 1986 IROC T-TOP
Transmission: 700-R4
I had the same problem and ended up taking the whole mount off and pulling the whole thing up from the top. Then picked up a used set of mounts in good shape to replace them. Eventually I am going to get some Spohn or J&M's, but didn't have the cash at the time. If you have the cash, maybe spring for them now.
Old May 23, 2010 | 10:53 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
I used a 13/16 wrench and used the closed side on the big strut nut, then used a 10mm socket on top and they turned free.
Could try and spray some penetrant oil on them?
Old May 23, 2010 | 11:21 PM
Stephen's Avatar
Car: 87 GTA
Hit it with an impact wrench. It'll come off faster than the strut shaft can spin.
That is the only way I've ever seen it come loose.
Old May 23, 2010 | 11:39 PM
Iroc Adio's Avatar
Car: 1987 IROC
Engine: Destroked 377
Transmission: TH-400
Axle/Gears: 9inch with 3.70's
x2
Old May 24, 2010 | 12:43 AM
jakemussman's Avatar
Car: 1990 Camaro RS
Axle/Gears: 10 bolt, 3.73 Ratio, Torsen LSD
Just pulled mine today. 21mm on the nut and 10mm on the strut shaft. pair of long armed wrenches and it came loose pretty easy.
Old May 24, 2010 | 11:21 AM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
When I pull my struts I use a strap-wrench on the shaft of the strut to keep it from rotating. Has worked well for me for the last fifteen years.
Ed1LE
Sep 30, 2018 09:14 AM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
gord327
Sep 29, 2015 10:18 PM
