36mm bushings & e-mail campaign
Old Feb 18, 2001 | 09:46 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Do you suppose an e-mail campaign to Energy Suspension (energysuspension.com) and/or other companies, concerning the need for 36 mm (greaseable), bushings would be helpful?
JamesC
Old Feb 18, 2001 | 03:28 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Nope, just not a high enough demand for that size to make it profitable for them.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 9/18/00)
There can be only one!!
Old Feb 18, 2001 | 08:00 PM
91B2L's Avatar
Car: 1991 Z-28
Transmission: TH700
I've tried several places for 36mm bushings.the kept sending 34mm. I finaly did it myself, with a dremel tool.I reemed the bushing out to fit my 91'z
Old Feb 18, 2001 | 08:11 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Well guldstrand makes 36mm sway bar bushings. They arent greaseable though, if you wanted them to be you would have to modify them yourself to adapt zerk fittings.
If the women don't find you handsome they should at least find you handy
88 GTA Notchback with 91 gfx and ROH Snypers
Aftermarket T-56 (pain in the A$S but worth it)
Lots of things to do still
Old Feb 19, 2001 | 10:35 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Not 100% sure, but I think PST sells 36mm bushings, and they are polygraphite so you do not need to grease them.
"Only in Britain could it be thought a defect to be “too clever by half.” The probability is that too many people are too stupid by three-quarters."
John Major
Old Feb 19, 2001 | 10:46 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
You don't need 36 mm bushings to fit the sway bar. The ES 34 mm fits fine. I modified them to be greasable though. I cut 3 circumferential grooves and 2 "X" grooves in the ID with a Dremel and an abrasive cutoff blade. I peeled it open and held it open in a vise to do the modification. I drilled and tapped the stock housing for the zerk fitting. I drilled through the bushing to match. Now it is greasable.
Old Feb 20, 2001 | 11:51 AM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
Just buy the largest Energy Suspension greasable bushings (34mm I believe).Then go buy a flap wheel for a drill from WalMart and bore it out to 36mm.Its pretty easy.
92Z28
89GTA
Ed1LE
Sep 30, 2018 09:14 AM
1Aauto
Sponsored Vendors
Oct 19, 2016 08:50 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
1Aauto
Sponsored Vendors
Oct 13, 2015 03:06 PM
loud91rs
Oct 5, 2015 10:05 PM
