What kind of Torque Arm is better?
Old Feb 21, 2001 | 07:10 PM
Fastbird's Avatar
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
The poluurethane bushing version or the spherical rod end version?
Old Feb 21, 2001 | 08:27 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Depends on how you use your car.
A rod end version has zero deflection so it's perfect for any sort of race car however it'll be hard and noisy for street use and they do wear out over time.
Poly bushings are quiet. They don't move around as much as rubber bushings but race cars don't want that extra movement. They'll last for a long time before wearing out.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
461 Big Block installed and ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
Ragtop Man
Sep 12, 2015 12:23 AM
WickedBowtie
Sep 11, 2015 11:24 PM
Nick McCardle
Sep 10, 2015 08:36 PM
