Mysterious Random side switching noise?
Old May 29, 2010 | 04:00 PM
knobs's Avatar
Car: 1989 IROC-Z L98
Engine: TPI 5.7
Axle/Gears: 2.77
This all started about February. Going down a curvy road, I turned the wheel left and all of a sudden a fairly loud roaring noise occured. It stayed that way for about two months (the car, an 89 IROC, wasn't being driven as I was at school).
I figured it was a wheel bearing, as it sounded similar to a bearing noise, and the passenger inner bearing wasn't packed properly and discolored in the heat. After a few more weeks (with the noise obviously not going away), it began to take on a new characteristic.
This is now. Also let me note that the noise doesn't occur at all if the wheel is completely centeredd. Say I'm going down the road, and everytime I just barely turn the wheel left the noise begins. I can roll the wheel just barely left and right and it will go on and off. Except randomly, the noise will stop being on the left and only occur when the wheel is turned to the right...
I have gotten the wheels balanced and aligned, and have new tires. Also, the noise gets louder the faster I go, and the harder I turn the wheel. It occurs under braking, accleration, cruising or coasting.
Help?
Old May 29, 2010 | 06:53 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
Re: Mysterious Random side switching noise?
did you replace the bad wheel bearing?
Ghettobird52
Jul 5, 2024 11:18 PM
theshackle
Sep 17, 2020 08:26 AM
B_Dubya
Aug 26, 2015 05:09 PM
TA8487
Aug 16, 2015 12:21 PM
BlackBoulder
Aug 11, 2015 11:15 PM
