Better than a 1LE suspension?
is there an aftermarket setup(springs, shocks, bushings, etc.) that will make my 1991 1LE perform the same(or better), but have a little smoother ride?
1991 Z28 305 5spd 1LE, TES headers, dual cats, 3 Chamber flowmaster, Comp cams .488/.495 212/218 the usual street racer with a stock chip.
Gained 20HP by porting and polishing my EGR passage.
Cars beaten as of 01/01/01
95 Acura Legend
Lost to as of 01/01/01
95 Acura Legend
Car: 91 Firebird 'vert, 91 Formula
Engine: 5.7, 5.0
Transmission: T56, T5
Axle/Gears: Auburn w/ 3.73's, 3.42
That's the whole reason the 1LE wasn't offered to the public as an option....b/c of the racecar like ride! Add polyurethane engine & trans mounts for an even harsher ride, I did, but it's so worth it performance wise!
'91 Z28 1LE; 355, Sportsman II heads, Edelbrock TPI w/ 58mm TB, Tremec TKO 5-speed, 3.73's & much, much more
When you find those magical springs let me know. I'll take yours.
Nor Cal Mike
Red 84 Z28 HO, stock L82 350, L69 carb, intake, and air cleaner.
5 Spd, 3:73 Posi, 1 5/8" SLP headers, 3"cat connected to
stock L69 exhaust, KYB's, homemade SFC's,STB and wonderbar
Some are faster but mine's fast enough.
Nor Cal Mike
Car: Take
Engine: Your
Transmission: Pick
No, the springs and swaybars are a misconception. In '92, there were only three front swaybars offered. Either the FE1, FE2, or F41. There is no "1LE" bar like everybody thinks. FE1 was the "soft ride" wich got the 30mm sway bar. The F41, which was the "firm ride and handling" had the 34mm, and the FE2, which wasn't just for the 1LE "package", it also could be had with the WS6 or Z28, as it was the 36mm.
As for the springs, there were about 4 different versions, none are 1LE specific.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
South East Thirdgen
Savannah, GA
'87 Trans Am
22# injectors,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
'97 Bonneville SSE
Car: '88 Formula
Transmission: T-5... in need of slight rebuild
What is the difference with the fuel tank??
'86 TA, T-tops, T-5, 3.73, 4 wheel disks 350, compucam 2040, performer intake,SLP Headers, 3" race magnum muffler, 1.6 Comp rockers, Ripper shifter, perf. friction pads, Hypertech ignition, Earls brake hoses, Hotchkis springs, Tokico Illumina 5 adjustable shocks and struts, Lakewood panhard and trailing arms
14.73 @ 95... traction still a problem
LT1Formula
Oct 8, 2015 08:34 PM
