Ball Joint Torque Spec
Old Jun 3, 2010 | 08:17 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
Anyone have the torque spec for the ball joint nut from a FACTORY service manual?
Depending on what page you look in a chiltons it could be 77 ft lbs, 170 NM , moog ball joint instructions 55-65 ft lbs, the internet... anything from "just hand tighten it!" to 65 ft lbs to 90 ft lbs.
Wish I still had my gm manual but loaned it out and never got it back
Old Jun 4, 2010 | 09:14 AM
fleetmgr's Avatar
Re: Ball Joint Torque Spec
Don't have a factory manual, but Alldata says 90 Ft. Lbs. for upper or lower on an '87.
Old Jun 4, 2010 | 09:45 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Interesting as well as confusing. I have three shop manuals. The 1985 (Camaro) says 78 ft. lbs, the 1987 says 90, the 1991 says 83 (both the later Firebird).
JamesC
Old Jun 4, 2010 | 11:35 AM
87350IROC's Avatar
Car: 87' IROC
Hmm I just did mine the other day. 1987 Camaro shop manual. 77 ft/lb
Old Jun 4, 2010 | 02:26 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Wow, this spec is all over the place. '92 FSM for a Camaro states 80 ft/lb. Plus 1/6 turn max to align cotter pin. I wonder who writes these specs?
Pablo, welcome back to the thirdgen world.
RBob.
Old Jun 4, 2010 | 02:52 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
I've never torqued a ball joint nut. I get it tight then turn till the opening lines up so I can put the cotter pin in. If you torque it to a certain spec, more than likely the nut wont be in the correct spot anyways so you will still have to tighten it more.
Old Jun 4, 2010 | 03:08 PM
JamesC's Avatar
Some of us are **** in such matters.
JamesC
Old Jun 4, 2010 | 08:39 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
JamesC
Yes, whether it be aircraft or my car, I don't trust my arm for German Torque (Good'ntight)
This is crazy how the spec is all over the place. I guess I'll shoot for one of the late model service manual specs.
RBob, thanks for the WB. I'm glad to be back.
Old Jun 5, 2010 | 02:36 AM
Guest
Guest
Posts: n/a
If that is what you installed, I would follow those instructions. If they're worth their salt, they provided a number that provides the proper amount of force on the fastener of the material they're using.
Old Jun 5, 2010 | 03:11 AM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
That's not what I installed "corner carver build in progress"
Ed1LE
Sep 30, 2018 09:14 AM
88CamZ
Oct 8, 2015 10:29 AM
loud91rs
Oct 5, 2015 10:05 PM
gord327
Oct 3, 2015 01:25 PM
meeklay812
Oct 1, 2015 03:46 PM
