Rear Swat Bar Specs
Old Mar 6, 2001 | 06:48 PM
Jim 86 Bird's Avatar
Car: '89 TA
Engine: LB9
Transmission: M5
Rear Swat Bar Specs
I have a '89 TA w/ the WS6, and I'll be changing the rear sway bar bushings soon. A friend of mine has a bar which he says is better than my current one (hollow for lighter weight and thicker for performance were his reasons) what are the specs of my STOCK bar so i can see if buying the newer one off of him for a couple bucks would be worth it?
http://www.tcnj.edu/~esposit3
  • '89 Trans AM, 305 TPI, 5-spd
  • '86 Firebird, 2.8, Auto
Old Mar 6, 2001 | 07:09 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
There are way to many misconceptions out there regarding this, so I will post to help "clear the air".
WS6 does not garuntee that you will get the largest sway bar out there. WS6 is a "special performance package" and does not concern the swaybars. If you want to know about your sway bar, you need to look at the "F" codes. This is what was available:
FE1: 30mm front, 18mm rear
F41: 34mm front, 21mm rear
FE2: 36mm front, 21mm rear
Now granted, if your car does have the WS6 package, I highly doubt that you got the "FE1" suspension package, but I'm pretty sure that many WS6's got out w/ the F41 suspension.
So to answer your question, only two rear bars were offered, 18mm and 21mm, and I don't think any 18's were installed on on WS6 cars. As for the "hollow" bar, that would be the 36mm and if I'm not mistaken, its just as strong as the 34mm, just lighter.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Mar 6, 2001 | 07:14 PM
Car: '89 TA
Engine: LB9
Transmission: M5
Thanks! I always figured WS6 meant everything got upgraded, but now i'll know better in the future.
Old Mar 7, 2001 | 06:20 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
GMTech,
I bought a front and rear from what I believe was a WS6 car and the front stablizer was 36 mm, the rear 24 mm. I've had both measured. What gives? By the way, my 85 IROC has the FE2 RPO and came stock with a 32 mm and 24 mm.
JamesC
[This message has been edited by JamesC (edited March 07, 2001).]
Old Mar 7, 2001 | 02:50 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yah, mine has FE2, and a 36/24 combo. I dont know if its stock.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
z28addict8490
Aug 7, 2015 08:48 PM
