How big is the swaybar on a stock 92 RS, hardtop, 305 TBI? Thanks guys.
I have a 1991 RS 305 TBI and oddly enough the blue plastic part # tag (on front sway bar) was still on the car which I bought about a year ago.
The RPO is F41. The part # according to the Chevy dealer shows 34 mm. I'm going to measure mine before I order new sway bar bushings to make sure as Ive read so many different size sway bars with this RPO code.
HTH
Matt
HTH
Matt
It depends on your RPO codes.
FE1: 30mm
F41: 34mm
FE2: 36mm
More than likely, you have the F41 suspension. I think the FE1 was reserved for the V6 cars, and the FE2 for the HO Z28s and T/A's.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
FE1: 30mm
F41: 34mm
FE2: 36mm
South East Thirdgen
Savannah, GA
'87 Trans Am
22# injectors,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
'97 Bonneville SSE
JamesC
close
I'm not too sure how reliable the RPO codes are. For example, my 85 IROC has the FE2 code but only has a 32 mm front sway (which is about to be swapped to a 36 mm).
JamesC
[This message has been edited by JamesC (edited March 12, 2001).]
JamesC
Thanks for the info. How do I measure the swaybar? Are the measurements you listed the diameter? Do I just wrap a string around the thing and figure out the diameter from that? (d = C/pi), duh, nevermind, I can probably use a micrometer. Anyway, thanks again!
Ok, what size is good to upgrade to?
I have a 91 bird 305,
Thnx
91 FireBird 305 V-8
no true mods,
ghetto rigged cold air intake,
People dont have a soul, its just something parents made up to frighten little children, like the boogie man, or micheal jackson..."
GheTTo Riggers INC.
We Make Mcgyver look Like Crap
Thnx
91 FireBird 305 V-8
no true mods,
GheTTo Riggers INC.
