Best Subframe Connectors?
Old Mar 4, 2001 | 12:37 AM
Cool Runner's Avatar
Car: 86 Trans Am WS6
Who makes the best sub frame connectors in terms of ridgidity? I need a solid foundation for my third gen. I want the best of the best, price is unimportant, solid handling is. I wasn't sure if the other replies below about subframe conn applied to this question since that person was looking for an economic set.
**Also posted in Racing/Autocross
1990 Firebird
LO3 Auto
Bone Stock and Fast as _ell
[This message has been edited by Cool Runner (edited March 03, 2001).]
Old Mar 4, 2001 | 11:48 PM
Spyder's Avatar
RK Sports, "Double Diamonds" kick major butt. Stiff as hell. When I pull into my driveway the car is soo tight that I will pick up one of the rear tires as I go in. Be sure though that you have them welded in. Those bolt ons are ****.
--Spyder--
1992 Camaro RS
LO3, T-56,centerforce clutch, ported and polished heads, Edelbrock Performer Intake, 14X3 Open Element w/ K&N, hiflow cats (and thats it), AC delete, alu drive shaft, 3.73 posi, 170 stat w/ fan switch, STB, Subframe connectors, KYB AGX, Eagle GSC, and poly bushings.
1982 Z-28
Project car, ZZ4 in the works.
Old Mar 5, 2001 | 02:38 PM
dnovotny's Avatar
Well, I have a t-topped '91 T/A with Kenny Brown SFCs. Those are what Spyder is referring to. I recently bought a '91 GTA hardtop, and I'm putting in two sets of SFCs at once (they don't interfere with each other), Global West and Alston. From my experience, KB are the best SFC on their own. But, if you're willing to pay and install 2, the other setup should be even stronger. However, the Alston/GW on their own aren't as good as the KB. Especially the Alstons, which don't connect the subframe along the outside rocker rail which really helps torsional stiffness.
Dave '91 T/A, '91 GTA
Old Mar 12, 2001 | 03:39 PM
camaro6spd's Avatar
what about the 79.99Competition Engineering ones is Jegs?
Old Mar 13, 2001 | 10:05 PM
tohigh4you's Avatar
i recently purchased the sfc from chassiseng for $80.....then i paid $25 to send them back....they require you to cut the floor pans in your 3rdgen...if youve got a nice daily driver i would spend the cash and buy spohn.....if youve got a serious racer.....cut the floor pans and pay $80....hope this helps....
1991 Formula 350 w/Paxton blower and many mods
13.1 @ 105
2001 Ford SuperCrew
91 SrS
Oct 7, 2015 04:32 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
Gordonr1973
Sep 29, 2015 11:59 AM
