subframe connectors
Old Mar 14, 2001 | 09:50 AM
MyBlackRocZ's Avatar
subframe connectors
what are the best subframe connectors i could put on my 87 Iroc 350. The only mod that would affect the instalation would be my 3" borla exhaust. Im looking for the easiest to install. If possible withoput dropping the exhaust.
Old Mar 14, 2001 | 10:55 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
For the best bang for the buck, I recommend the South Side Machine weld-in sub-frame conectors. The part number is 1415 and they're around $150 from Summit or Jegs. They get stitch-welded along the rocker panels from the front mount of the rear trailing arm up to the back of the front sub-frame, close to where the front lower control arms mounts to it. You might need to drop either the cat or the Y-pipe down to install them, depending on how much clearance you have in that area and how good the shop installing them is.
Greg Westphal
'87 IROC 305TPI/A4
91 SrS
Oct 7, 2015 04:32 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
Gordonr1973
Sep 29, 2015 11:59 AM
