tire vibration help please!!!!!
Old Mar 18, 2001 | 02:25 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
Transmission: 700-R4
Axle/Gears: 2.73 G80
when i drive for about ten mintues down the road my front tires start to vibrate when i turn the wheel a little bit.like i only turn it enough to stay in the lines and turn the way they go. it only happens when i'm going about 50MPH. i know its not the tires cause they are brand new with not more than 1000 miles. I heard this could be the wheel bearing does this sound like a possibly?
any help would be appricated.
Old Mar 19, 2001 | 10:33 AM
MikeZ28's Avatar
Car: 92 Z28 Z03
i really need help!!!!!!!!!!!!!!
Old Mar 19, 2001 | 11:12 AM
82camaro's Avatar
Car: 82 camaro SC
could be bearings. turning left put more pressure on the right bearing and vice-versa.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old Mar 19, 2001 | 01:54 PM
Jza's Avatar
Jza
check by grabbing the tire and trying to wiggle it left to right and top to bottom.
also check your lug nut torque.
Old Mar 19, 2001 | 06:56 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
82 camaro that is it. when i turn one side it does it. then i turn the other way and it happens to. that is what i was told.
thanx 4 the help
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Lbibb
May 5, 2016 12:00 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
