Steering problem?
Car: 1984 Z28
Engine: LG4 305
Axle/Gears: 3.23:1
Steering problem?
Okay, when I'm at a dead stop, and turn my wheel all the way to the left, i hear a slight creaky noise coming from up. If I start to accelerate with the wheel cut, The driver's front wheel sort of....hops. I initially thought it was a massively messed up wheel bearing, so i replaced them, and it still does the creaking and hopping. Any suggestions what to check? I heard it could be the ball joint or the alignment.
Car: 1987 Z28 / 1988 IROC-Z
Engine: 305 LG4 / 305 LB9
Transmission: T5 5spd
Axle/Gears: 3.42 / 3.08
Re: Steering problem?
Hopping sounds like the sway bar end links are bad. Probably broken completely off. I had the same problem. Found both sides were broke. Replaced them, fixed the problem. Still have squealing, however I'm led to believe that's just the pump/belt, and haven't really looked into it as it only happens when cranked going around a corner.
backtothe80s
Sep 5, 2015 12:39 AM
