Where can I get good cheap rear rotors?
Old Mar 18, 2001 | 04:04 PM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
89 and up rear disc?
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Old Mar 23, 2001 | 11:26 AM
Superblue87Formula's Avatar
they are like 20 bucks at autozone..
Old Mar 23, 2001 | 07:44 PM
92TRANSAMWS6's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Superblue87Formula:
they are like 20 bucks at autozone..</font>
Yeah...mine were about $50 dollars each.
92 Trans Am WS6
Old Mar 27, 2001 | 09:17 PM
BLACK Z's Avatar
Car: 86 Z28
btt
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Eric-86sc
Apr 3, 2016 03:52 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
