Swapping a Disc Brake rear into my '83
Car: 1983 Z28
Transmission: WCT5
hey all,
I've got a wrecked '89 IROC sitting on the trailer still. the rearend is out and I'll put it in my '83 someday. My question is about the metric/standard issue I'm gonna run into on the brake lines
. would it be easier to yank all the lines and everything off of the '89? I just figured If I was going to do it, I should do it now because the remains of the '89 will be leaving shortly.
thanks for any advice on performing this swap into an earlier thirdgen. Any help is appreciated.
Clem
1983 Z28 with LG4, 5 speed, and (unfortunately) T-tops
1983 Z28, (unfortunately) auto, NO T-tops----FOR SALE---
Looking for a V8, 4 or 5 speed Camaro with NO T-tops (wanna trade?)
. would it be easier to yank all the lines and everything off of the '89? I just figured If I was going to do it, I should do it now because the remains of the '89 will be leaving shortly.thanks for any advice on performing this swap into an earlier thirdgen. Any help is appreciated.
Clem
one thing i think you could do is custom make your brake lines with the fitting you need on each end. i don't know but i bet if you look you can find adapters too for this.
ICON Motorsports
1st & 3rd
ICON Motorsports
1st & 3rd
Car: '87 Firebird
Engine: '89 Corvette L98, unstock
Axle/Gears: 3.23 posi
YES!!!!
Yank the lines(they're a different size than drum brake lines), the master cylinder, and the proportioning valve.
You will need all of those for the conversion to work properly
Redbird
Bayou Motorsports
87 Firebird-Daily Driver/Autocrosser
84 Z28-Full bore Autocross car
Delta Region SCCA
#00 C Prepared
Redbird
Bayou Motorsports
Delta Region SCCA
#00 C Prepared
Car: 1983 Z28
Transmission: WCT5
I already had the prop valve and mastercylinder. I was leaning toward yarding the lines too. guess it IS a good Idea
thanks
Clem
1983 Z28, (unfortunately) auto, NO T-tops---FOR SALE---
thanks
Clem
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
novaderrik
Aug 10, 2015 12:44 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
