converting to 1LE brakes???
Old Mar 28, 2001 | 07:08 PM
Wraith's Avatar
I have a 91 GTA that has rear drum brakes on it and I an converting to rear disc by swapping the rear end for a differant one. And I am putting on the 1LE setup in the front. Am I going to have to change the master cylinder and pro. valves. IF so can someone help me with the part number. Thanks
1991 Trans Am GTA, Accel 300+ ignition, underdrive pulleys, AFPR, Accel SuperRam (ported out), Edelbrock lower intake (ported out), BBK 58mm TB, TFS 23* heads, SLP 1 3/4 headers, SLP 3" cat back (no cat), CompCam .495/.502 lift, Kenny Bell strut tower brace, lower frame brace, Jeg's SFC, Lakewood trailing arms and panhard rod
Pony's can run, but bird can fly
1987 Buick Turbo-T
1977 Chevy Blazer 4X4
Old Mar 28, 2001 | 07:24 PM
jayg's Avatar
Car: 1992 Formula 350
Check this site out AndyZ28 and I are making.
http://www.geocities.com/rgades/1LE.html?985236018930
Old Mar 29, 2001 | 04:59 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
You will need GM part# 10136840 proportioning valve. You will use your existing master cylinder.
82Z 305 w/comp 270 magnum cam,Edelbrock Performer RPM,Holly 1850-4,serpentine belt drive.TH700R4 w/B&M holeshot 2000 converter,& megashifter.1LE front brakes, 9bolt 3.27 w/1LE rear brakes.Aluminum driveshaft,boxed rear susp.poly everything,IROC swaybar+wonderbar. 70mph@2200rpm ASE Master Tech plus L2
also recently obtained a
'69 chevelle SS396 w/Turbo 400,3.31 posi,11.0 to 1, headers,etc. Latest project car,'86 IROC stock 305TPI hit on left side,but not too bad
Old Mar 29, 2001 | 05:59 AM
Wraith's Avatar
Thanks for the info. What kind of diferance will I notice after doing this? It kind of sucks right now. I have to push hard to stop the car and keep it stoped not to mention when your doing 100mph.
1987 Buick Turbo-T
Old Mar 29, 2001 | 05:33 PM
ANDYZ28's Avatar
Car: 1982 Z-28
You will be amazed at the difference. But you should install the 1LE rear discs also. That way you will have 12" rotors on all 4 wheels.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
dyeager535
Aug 28, 2015 08:10 AM
