1LE brake upgrade questions
Old Mar 30, 2001 | 03:13 PM
lexussc94's Avatar
After reading all of the posts, I would like to upgrade my brakes, but I have a few questions.
Do I need to replace my master? I have an 85 IROC with 4 wheel disc. Also what proportioning valve do I need,if I have to change mine.Will the brake line fittings fit on the new valve?
Did the 1LE have different rear brakes then my car? If so does anyone have the GM part #s for all the rear brake parts that I would need?
Thanks in advance
Old Mar 30, 2001 | 08:29 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
Check out the 1LE posts elsewhere on this page.It will answer some of your questions. Your master cyl will be reused. The proportioning valve will change GM# 14089496.
All of your brake lines will fit.Only '82 to early '84 will have to mod the brake lines. Perhaps someone else can hook yuo up with the Bill Fong page. That covers the rear brake mod pretty good.
Jay,and I have covered the front brake mod pretty thoroughly. Check for other posts on this page,and our web page. Many photos&part#s.
82Z 305 w/comp 270 magnum cam,Edelbrock Performer RPM,Holly 1850-4,serpentine belt drive.TH700R4 w/B&M holeshot 2000 converter,& megashifter.1LE front brakes, 9bolt 3.27 w/1LE rear brakes.Aluminum driveshaft,boxed rear susp.poly everything,IROC swaybar+wonderbar. 70mph@2200rpm ASE Master Tech plus L2
also recently obtained a
'69 chevelle SS396 w/Turbo 400,3.31 posi,11.0 to 1, headers,etc. Latest project car,'86 IROC stock 305TPI hit on left side,but not too bad
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
gta90
Sep 15, 2015 04:00 PM
redmaroz
Aug 16, 2015 11:40 PM
