How can you tell if your rear shocks are blown?
Old Apr 6, 2001 | 05:34 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I lowered my car 2 weeks ago and had problems with the car bottoming out every now and then.
We'd push down on the rear and it felt fine.
I replaced the shocks with KYB shocks because I thought the old shocks weren't firm enough. The old shocks were actually blown, but driving in the car they seemed fine.
How do you know when they go bad?
Zepher
'86 Pontiac Trans Am WS6, LG4 305, 5 Speed, CF DF Clutch,
Edelbrock 1406 Carb, Edelbrock Performer RPM 7101 Intake Manifold.
Edelbrock Open Element Air Cleaner: Flowmaster Exhaust, 160* Thermostat,
Grant GT Steering Wheel, MSD HEI Coil, Taylor 8mm Wires, Leather 96 Camaro SS Seats,
Alpine CD+Changer,Alpine V12 Amps, Premier TS-1040C Subs, Polk Audio highs/mids.
Best ET: 14.94@91.67
High Speed Run: 157mph
WS6 Trans Am
Old Apr 6, 2001 | 05:43 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
They usually go bad by leaking their fluid out. So any oil on the bottom half of the shock is a good indicator that they are toast.
ICON Motorsports
Old Apr 6, 2001 | 10:41 PM
Camaro_hunter_d's Avatar
well the ase way is very complicated, the easy shade tree way is bounce the rear end...if it "rolls" up and down then the shock is bad. I had very baddly blown struts in my 92 cam and I would have never knew had I not bounced the front and it did not refuse to go down or bounce a little.
Old Apr 7, 2001 | 01:12 PM
82camaro's Avatar
Car: 82 camaro SC
I had a pair of shocks that broke internally. They would push down(compress easily), but would rebound with resistance. Kind of like drag shocks. I would bottom out, but I couldn't make the rear end bounce while checking the shocks. They weren't leaking and looked perfect. Just to let you know that the bounce method doesn't always work.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old Apr 8, 2001 | 09:22 AM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
My car bottomed out when I would go over any dips.... Thanks to KYB it no longer does...
BTW, when I replaced them, I pushed them down out of the top holes with one finger... now that is baaaaad.
http://kiztope.50megs.com
92 Rs 3.1/T-5
Its slowly but surely coming along....
AIM : Theonekiztope
ICQ: 8787542
Planetarion: 3GFB kiztope of kiztopia-Camera-92RS-A (33:6:14)
"If it can be better than it is, make it so!" Leon Calrinsky (00)
customblackbird
Aug 15, 2021 10:16 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
NORTz89
May 20, 2020 03:51 PM
LT1Formula
Nov 16, 2015 01:13 PM
kevyb1973
Aug 24, 2015 04:11 PM
