$291 per Caliper...That is NUTS!
Old Apr 6, 2001 | 10:23 AM
Thor's Avatar
I just called the Chevy Dealer and they informed me I would be paying $291 apiece for new rear calipers. This is not even remotely possible for me but I need back brakes. Suggestions for a good rebuild kit or something.....
1987 IROC-Z
14.22@95.6mph
5.7 TPI, Black, ASCD SS hood, 89 IROC rims.
Old Apr 6, 2001 | 10:54 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Check any parts store, you should be able to get a remanufactured loaded caliper for I'd guess $80 to $120 depending what kind of pads it comes with, plus probably a $50 refundable core charge.
Old Apr 6, 2001 | 08:10 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
That's right!!
82Z 305 w/comp 270 magnum cam,Edelbrock Performer RPM,Holly 1850-4,serpentine belt drive.TH700R4 w/B&M holeshot 2000 converter,& megashifter.1LE front brakes, 9bolt 3.27 w/1LE rear brakes.Aluminum driveshaft,boxed rear susp.poly everything,IROC swaybar+wonderbar. 70mph@2200rpm ASE Master Tech plus L2
also recently obtained a
'69 chevelle SS396 w/Turbo 400,3.31 posi,11.0 to 1, headers,etc. Latest project car,'86 IROC stock 305TPI hit on left side,but not too bad
Old Apr 9, 2001 | 03:44 PM
Kyle F's Avatar
Mine were $80 a piece on the 86 T/A form autozone
FOR SALE!!!!!!!!!!!!!!!
86 Trans Am 355 TPI Rebuilt 700R4 with Corvette servo, modified valve body, and a B&M Torque Converter (2000 rpm stall w/ lock up), 87 350 block bored .30 with new crank. Reworked 305 heads with 3-angle valve job. Added in the rebuild was an SLP TPI cam, BBK 58mm Throttle Body,MSD 6A, Hypertech Power Coil,MSD Wires, 1.5 Crane roller tipped rocker arms, SLP Intake Runners and Port matching in upper intake including fully ported plenum, TPIS adjustable fuel pressure regulator @ 46psi, Hooker shorty style headers w/ Thermotech heat wrapping, Custom 3” exhaust with Flowmaster muffler and chrome quad tips, Hypertech Thermomaster Computer chip, K&N open element cone filter on modified MAF per TPIS specs, removal of A/C hardware and added a 1LE firewall cover installed. Also there has been a PST front suspension kit with Hotchkis strut tower brace added.
Stereo has 2 Clairion Pro Audio dash plates, 2 Sony 6X9s, 2 Kicker 12's in a custom Carpeted box with a custom amp rack Holding 3 MTX 280 Amps, and a MTX electronic Crossover all wired with EFX cable.
Asking $4200 with all extra Parts that are needed to fix most apearance flaws. ie Complete hatch and wing from a 91 GTA
http://geocities.com/feltsb/kyle.html
Kills:
95 Talon TSI, 96 Probe GT, 91 T/A L98, 89 RS, 86 Mustang GT, 88 Mustang LX 5.0, 92 Thunderbird V8. couple or ricers that I think were Civics or Preludes not sure what year, 95 Celica GT-S, 94 Chevy 1/2 ton 350, one of those NASCAR F150's
89 Trans Am Turbo 3.8L All stock 43,000 miles #1053 of 1555
Old Apr 10, 2001 | 12:51 AM
Mikos_89's Avatar
Car: '89 GTA, '15 Camaro LS 6sp.
Engine: L98, LFX.
Transmission: 4L60, AY6.
Axle/Gears: 3.27's.
Unless the calipers are permanently damaged in some way, you don't need to purchase new or rebuilt ones.
Just buy a "rebuild-kit" from your local Chevy/Pontiac dealer like I did. It sure was a lot cheaper than buying new/rebuilt ones.
Interestingly enough, the (smaller) rear brake pads cost more $$$ than the (larger) front brake pads. You know, like nearly twice as much $$$ for nearly half the surface area.
Goodluck!
'89 GTA: blk on blk with 5.7 liter, T-tops, leather, N10 dual exh with 76,500 original miles. 100% stock including the ZR50 Goodyear "gatorback" tires.
Old Apr 10, 2001 | 01:43 AM
pookey's Avatar
I am lucky enough to have a friend that works for a chevy dealership in the parts deparment. He is getting me a set of fully loaded calipers for $40 each. He may be working some kind of magic and I am smart enough not to ask how he is doing it. Or he could be the devil.
Old Apr 10, 2001 | 07:17 AM
HighHorseZ's Avatar
http://www.gmpartsdirect.com
They offer MUCH better prices than the dealer, usually!
Good luck!
Mike
86 Z28
305 TPI
3.73, Flowmaster, TPIS Air Foil, Headman Headers, March Pulleys, K&N, Hypertech
timonator
Sep 30, 2015 12:52 PM
gord327
Sep 29, 2015 10:18 PM
3.8TransAM
Sep 27, 2015 08:37 PM
aharvel50
Sep 21, 2015 07:31 PM
Fox118
Sep 12, 2015 09:29 PM
