Panhard bar, Bolt hole Ovaled out?
Old Jul 18, 2010 | 05:38 PM
WhiskeyChick's Avatar
Car: 1987 Trans Am GTA
Engine: 305 V8
Transmission: 5spd
Axle/Gears: 9bolt
Alrighty, so im changing all my old bushings in my GTA mainly because there was a annoying squeek coming from the panhrad bar, and I assumed its bushings.
However, get the panhard bar out, and the bushings are perfectly fine. The actual bolt hold on the passenger side of the car is ovaled out slighty. Anyone else have this issue??
Any way to fix it without going with an oversized bolt/bushing?
Old Jul 18, 2010 | 05:46 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Panhard bar, Bolt hole Ovaled out?
weld washers to the mount
Old Jul 18, 2010 | 05:47 PM
Twin_Turbo's Avatar
Weld a tight fitting washer over the hole
Looks like 86TA beat me to it
Old Jul 18, 2010 | 06:36 PM
Engine: 305 V8
Transmission: 5spd
Axle/Gears: 9bolt
Thanks, but actually the new bushing kit sleeves had a little more room. So I fit a bolt that was like 1 or 2mm bigger and had to redrill out the holes inthe car. Now no slop in sleeves, bushings, or mounting holes
customblackbird
Aug 15, 2021 10:16 PM
evilstuie
Jan 9, 2020 08:29 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
deracer
Apr 11, 2016 12:04 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
