Need advice w/ roof, SFCs, and roll cage...
Old May 9, 2001 | 01:17 PM
MILT's Avatar
Good afternoon. Here's the skinny: I have a car w/ a damaged driver's side and roof, and a nice car w/ mint driver's side and t-topped roof. I want to have car A repaired with car B's parts--including having the roof swapped over. Now, I know this will result in a weakened frame and the like, but I also want to install a 4 or 6pt cage. Should installation of the cage and SFCs strengthen the frame suitably? Also, any bdy guys know what this might run me???
Old May 10, 2001 | 10:05 AM
Nor Cal Mike's Avatar
"including having the roof swapped over." I assume by a body shop. My money says it would be cheaper to buy another car.
Nor Cal Mike
Red 84 Z28 HO, stock L82 350, L69 carb, intake, and air cleaner.
5 Spd, 3:73 Posi, 1 5/8" SLP headers, 3"cat connected to
stock L69 exhaust, KYB's, homemade SFC's,STB and wonderbar
Some are faster but mine's fast enough.
Old May 10, 2001 | 02:42 PM
Jed's Avatar
Jed
Car: 89 Formula 350
Engine: 360 / HSR
I'm confused, do you mean you want to use the t-top car to fix the hardtop car? I don't get it...
I have installed Alston SFC's along with a four point roll bar in my t-top equipped car. Before I added these pieces, when I would cross over railroad tracks, for example...it felt like the front of the car would move one way and the rear of the car would move a different way, like they were not securely connected. As I understand it, this is just the nature of the vehicle.
With the sfc's and bar, the car now feels much tighter, like a car with a full frame. I do not feel body flex anymore.
Technically speaking, a 4, 6 or 8 point setup is a roll bar, not a cage.
10 & 12 point sytems are cages.
Hope this helps.
Jed
89 Formula 350
Old May 11, 2001 | 09:47 AM
MILT's Avatar
Yes, that's exactly it--fix hard-topped car w/ t-topped roof. I know it will cost a lot, but don't want to buy another car--don't ask why.
Old May 11, 2001 | 01:02 PM
82camaro's Avatar
Car: 82 camaro SC
If cost is not a problem, it can be done and would be plenty stiff with a good cage and SFC's.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
neekolzun
Aug 24, 2015 04:59 PM
titoislaidlow
Nov 14, 2003 03:36 PM
89GTA350
Aug 2, 2003 01:31 AM
drop-top IROC
Southern California Area
Oct 14, 2002 10:40 PM
erictheviking
Aug 23, 2002 10:55 AM
