Will 9 bolt disc brakes fit on a 10 bolt disc rear?
Old May 14, 2001 | 12:00 PM
FormulaJoe's Avatar
I found a 10 bolt with some 4.10s in it for a pretty good price. Can I take the brakes off of my 3.27 9 bolt and use them on this 10 bolt. The guy said it is a disc brake rear end it just doesnt include the brakes.
Does anyone know? Id appreciate any help/suggestions.
L98, 3.27 9-bolt, Hooker shorty headers, custom 2.5inch Y-pipe, no cat, 3inch 2chamber flowmaster, JET AFPR, Ported MAF, Best ET: 13.86 @100mph. 1.99 60'
17 inch ROH "ZS" wheels. 17x8.5(front) and 17x9.5 (rear). Firestone Firehawk SZ50s. 245/45/zr17s and 275/40/zr17s. T56
On the way... Radar Blue 89 Formula, T56, Ram Jet 430, Ram Air, 17inch ROHs.
Old May 14, 2001 | 01:14 PM
ede's Avatar
ede
no don't think it'll work.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old May 14, 2001 | 02:22 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
As long as they are the same stye brakes, ie early style or aluminum PBR style and, it will work. The only difference difference between the 2 systems is the backing plates. And at that the only difference between the 2 backing plates is the bolt pattern. Sure man I would go for it. Worse comes to worse you have to redrill your backing plates for the correct bolt pattern.
If the women don't find you handsome they should at least find you handy
88 GTA Notchback with 91 gfx and ROH Snypers
Aftermarket T-56 (pain in the A$S but worth it)
Lots of things to do still
Old May 14, 2001 | 02:41 PM
FormulaJoe's Avatar
So, as long as they are both 89 & newer, it will work? My 9 bolt is an 89 and I believe they changed the rear discs in 89 right?
Now, if the 10 bolt is newer than an 89 it should work I guess. Am I correct in assuming this?
Old May 15, 2001 | 01:23 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yes... I put my 91 10-bolt brakes onto my 89 9-bolt rear end when I swapped. 82-88 is one style, and 89-92 is the other style.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old May 15, 2001 | 08:25 AM
FormulaJoe's Avatar
Sweet! Thanks for the help guys. It is much appreciated.
Old May 15, 2001 | 11:27 AM
Tad's Avatar
Tad
Just to let you know. I have put 89 and new rear disc brakes on a rear end out of 87 T/A(with for 4 wheel disc) and everything bolted right up.
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Jan 19, 2016 12:21 PM
novaderrik
Aug 10, 2015 12:44 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
