How will same wheel backspace look/fit?
Old May 23, 2001 | 12:31 PM
Rat 427's Avatar
From what I've read the rear wheels have more backspace than the fronts. I want to buy aftermarket wheels 16x8, but dont want the rear wheels to look narrower because the offset takes more of the 8" rim to the inside. If I order all 4 rims with the same offset as the front how will things fit and look. I can take out the 1/8" rear spacer installed in the rear.
Thanks for you input.
Bruce
When the green flag drops, the bull%#$@ stops.
1979 Z28 w/427 Street/Strip car
1988 Iroc Convertible
Old May 23, 2001 | 12:53 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
The only reason that spacer is on there is because the steel drum is thinner than the aluminum drum. The spacer you are talking about has very little effect on the back spacing.. i wouldn't worry about having it on or not having it on. The tire "might" rub a little under hard cornering or it might not. I don't think its a night and day difference with it off or on.
  • 89 Formula 305 WS6
    SFC's, LCA's, Air Foil
    Spohn Panhard Bar
    Flowmaster Cat Back, Tranny Cooler
    A/F Ratio Meter (not a mod but it sure spurs interest)
    Trans Temp Gauge
    Most "Free" Mods
    3:73, Zexel Torsion Posi
  • 90 Eagle Talon 2.0
    (Winter Beater)
    Mods? Um, no
Old May 23, 2001 | 12:57 PM
Rat 427's Avatar
That what I thought the spacer was for, figured I could just dump it anyway to gain just a little back.
Will the backspace being the same look alright. How much difference is there really between front & rear backspace. I've been to lazy to take the wheel off my 88 and mesure.
Old May 24, 2001 | 11:36 AM
GiddyUP305's Avatar
Engine: turbocharged 4 cyl Dohc
Transmission: 5 spd sentronic
i have a set of iroc knock-offs on my bird, there in no back-spacing on these wheels(this is a set of s-10 LS wheels
91 firebird vert
tan top&interior
305/700r4<br>MY SITE HERE
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
rb85TA
26
Sep 14, 2015 10:29 PM
Brian Anderson
Wheels and Tires
Sep 12, 2015 06:12 PM
punkmaster98
Sep 8, 2015 09:45 PM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
