no brakes after driving long distance
Old May 19, 2001 | 06:06 AM
zz4mula's Avatar
Car: FORMULA 350
Engine: ZZ4
A few weeks ago I took my 4mula on a trip from Florida to NY. The trip was a blast as I was free of my wife and kids. Just me on th open road. But along the way, I noticed that my braking ability went south over a long period of driving. The brake light would come on when I applied the brakes. This happened even going thru Washington DC. When I stopped for fuel and a ****, the brakes would come back. I am thinking that maybe my headers are just a little too close to the prop valve and may have caused the fluid to boil. What does the board think? I haven't driven it since I got back because I am too lazy to even wash it right now.
Old May 19, 2001 | 10:35 AM
Andrew H's Avatar
the pads might be rubbing too hard against the rotor causing them to overheat -that would cause fade with distance -it might also cause serious damage such as cracks -but I can't think of anything else right now... sorry
Old May 20, 2001 | 12:18 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
My headers, along w/ many other peoples headers run pretty close to the brake lines and nobody has had this problem before (not that it can't happen, just seems unlikely.
I thinking more on the lines of a brake dragging. Maybe like a bad rubber line holding pressure on a certain wheel. The longer you drive, the hotter it will get and eventually boil.
Just some thoughts. If you are concerned about the heat of the headers, put some heat shielding around the lines and prop valve.
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
'97 Bonneville SSE
Old May 21, 2001 | 08:33 PM
clemsparks's Avatar
Car: 1983 Z28
Transmission: WCT5
hey,
this may not be the case, but I had this happen on the racecar before (TransAm Series camaros and mustangs). If your rotors are warped you'll get pad knockback. This pushes all pistons back into the calipers. The first time you push the pedal, all the travel is used to push the pads back up to the rotor. then the brakes are fine...until the end of the next straight.
Probably not your problem buy who knows, it could be a contributing factor (do our calipers have anti-knockback stprings...anyone?)
Clem
Clem
SCCA TransAm Series Race Mechanic/CrewChief
1983 Z28 with LG4, 5 speed, and (unfortunately) T-tops
1983 Z28, NO T-tops, (unfortunately) Auto Transmission (hopefully not for long)
Old May 24, 2001 | 05:09 PM
Cosmik Debris's Avatar
I have had the brake fluid boil from excessive use in hilly country with much the same symptoms as you are describing. I would replace the fluid first. It doesn't take too much water or other contamination in brake fluid to drastically lower it's boiling point.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
kyleb24
Aug 15, 2015 08:24 AM
