V6toV8 suspension, and big honkin sway bar
Old May 27, 2001 | 10:34 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
I bought a 89bird V6 for 300 bucks. I am putting a 350 in it and a TH350. I want to upgrade the suspension also. I found a 89 formula in the junkyard, it has the biggest honkin sway bar i have ever seen on a car. I have seen some IROC's in the junkyard and they have the same size sway bar as on my V6 brid. Any idea what size the big sway bar is on the formula. Is it a 36mm? Also, on the formula, i am assuming the rear sway bar is big too. the car is sitting on the ground with no tires, i cant see the rear one. One last question, are the brakes bigger and/or better on the formula? thanks for the help. I have been working on cars for a while now, but dont know much about Fbody suspensions.
oh, and what the hell is a wonder bar?
Wide Open Till You See God...Then Brake
J-money
Jan 4, 2019 09:45 AM
camaro1185
Oct 26, 2015 06:51 AM
Lanz06
Sep 14, 2015 07:16 PM
87camaro87
Sep 9, 2015 10:29 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
