new rims & tires
Old Jun 1, 2001 | 05:13 PM
slowcar's Avatar
new rims & tires
I will keep looking in the archives but I'm not having any luck. I am buying 17x9.5 rims and I want to put 275's all around. Can I do this with my 89 IROC? I really want these tires and wheels to fit. Any help is greatly appreciated. If you think I will get better responses on a different board let me know.
thanks guys
Old Jun 2, 2001 | 08:51 AM
88CovertibleTBI's Avatar
I don't think they will fit. With a stock camaro, a tire with a width bigger than 245 is not recommended in the front and 255 in the back. Not just that but its not recommended to put rims on your car bigger than 17X8. You could mount these rims and tires on the car but listen. You would have to use wheel spacers in the front to fit the tires. Probablt one or town. Wheel spacers in the back too. I suggest you raise the car by installing higher springs or your fender will be digging into the tread of the tire everytime you hit a bump. Now, here are the good results and the bad results from doing all this. The good result is....You can put the tires you want on the car, your car will leave a bigger footprint and add better traction, it may look cool. The bad result is that you won't be able to steer your car because the tires will be digging into your wheel wells when you turn the steering wheel, the tires will be sticking out of the wheel wells which is illegal in most states due to the effect it has on drivers behind you in the rain, your handling will change dramatically. If you have any other questions, email me. Thanks.
- Jax
jaxvindick@aol.com
Old Jun 2, 2001 | 09:55 AM
AT4 T/A's Avatar
Car: 1989 IROC-Z
Engine: L98 350
Transmission: New 700r4 Done by 11/14/07!
No, it WILL fit! In a pretty recent Super Chevy article they gave the largest rim sizes they could put on a third gen Camaro. This is what they said:
17x8 all around with 4.5" of backspacing
(255/40 R17)
17x8 front with 4.5" of backspacing
(255/40R17)
17x9.5 rear with 5.5" of backspacing
(285/40R17)
17x9.5 all around with 5.5" of backspacing
(275/40R17)
Just so you know, they put 275's all around on a Camaro that was lowered one full inch and had NO clearance problems without using spacers.
That's the gospel according to Super Chevy!
[This message has been edited by AT4 T/A (edited June 02, 2001).]
Old Jun 2, 2001 | 11:02 AM
slowcar's Avatar
How tall were the tires they used in the article?
thanks
I really want them to fit
Old Jun 2, 2001 | 01:23 PM
jayg's Avatar
Car: 1992 Formula 350
I have 275/40/17 fronts 315/35/17 rears...ZR1 wheels...2.5" & 1.25" adapters to make them fit. They do not rub at all.
Here is a pic.
http://www.geocities.com/rgades/ZR1.html
Old Jun 2, 2001 | 02:53 PM
AT4 T/A's Avatar
Car: 1989 IROC-Z
Engine: L98 350
They were using 40 series tires.
Hotrodboba400
Dec 10, 2019 07:07 PM
brockerboy
Wheels and Tires
Sep 17, 2015 03:59 PM
dennisbernal91z
Wheels and Tires
Sep 12, 2015 12:28 AM
fasteddi
Sep 10, 2015 09:32 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
